Looking for ways to pass on a filter expression from a widget to the Attribute Table to update the AT display based on the query, rather than opening another tab.
The table displayed in the AT is not the attribute table from the layer, but they share a unique id.
Perhaps perform the query at the widget, then close the AT and open it with the results you pass on from the widget query?
Thank you.
Lefteris,
Have you seen this sample:
Or this thread:
Thank you Robert.
I tried applying this
var partsObj = {
"expr": the_expression,
"parts": []
this.wManager = WidgetManager.getInstance();
if (this.wManager) {
var widgetCfg = this._getWidgetConfig('AttributeTable');
if (widgetCfg) {
var attWidget = this.wManager.getWidgetByLabel(widgetCfg.label);
var activeTable = attWidget._tableFunctionController.getActiveTable();
activeTable.setFilterObj(partsObj);
activeTable.refresh();
}But I get this error.
The attWidget is not null.
UPDATE:
I turned on the visibility for a feature layer on the AT and it works.
The other table that I was trying to apply the filter on is actually a non-spatial table from web service.
I guess the filter is not working for tables in AT?
I am pretty sure no spatial tables do not work in AT Widget.
If I apply the filter on the non-spatial table, it displays the results. Could we call the filter programmatically on this table.
It seems it can be done. I am posting in case someone else, want to query a non-spatial table in the AT:
for example:
the_expession = "UPPER(<field>) LIKE '%<something>%'"
var partsObj = {
"expr": the_expession,
"parts": []
this.setFilterObj(partsObj);
this.clearSelection(false);
this.startQuery();
this.emit('apply-filter', {
layerInfoId: layerInfo.id,
expr: partsObj.expr
