Asynchronous call in postCreate
1757
12-10-2018 08:46 AM
JaysonLindahl
I have a widget that needs to get information from a geoprocessing service on creation in order to populate a table.  Even though I've setup the geoprocessing service to be synchronous, it seems like the code is behaving as if it were asynchronous (at least the postCreate/startup/onOpen functions).
What I'm doing: (not sure how to make it look like formatted code, but here I go.)
postCreate: function (){
   this.inherited(arguments);
   myGPfunction();
   followupFunction();
startup: function(){
onOpen: function(){
   //do something
I can get the followupFunction() to wait for myGPfunction() (I've figured out how to incorporate the .then).
My problem is when I click to launch to widget in my map, postCreate,startup,onOpen all fire off.  I see in the console that PanelManager & WidgetManager say my widget have been created, then I see my results from the myGPfunction after that.
How do I get things to wait until I receive my data before continuing with creation?
Tags (1)
RobertScheitlin__GISP
Jayson,
   You do not have control of the widget life cycle events and delaying their execution. You need to re-examine your work flow and adjust.
Jayson,
JaysonLindahl
I was afraid of that.  I assume the startup and onOpen functions operate in the same manner?
Correct
