Applying "opacity" into the Basemap Gallery
1992
09-05-2016 05:30 AM
deleted-user-CQZbjNeBXm49
Hi All,
Please is there a way to applying some transparency to the Basemap Gallery (js code or alternative)?, so as not to confuse a user when they add layers onto the background images......
Please kindly assist.
Thank you
Baba
Tags (1)
RobertScheitlin__GISP
Baba,
   If you look in the eBasemap Gallery Widget you will find that I apply transparency to basemaps so they can be merged together. You can use some code form that widget.
https://community.esri.com/docs/DOC-2888
Thanks for the guidance rscheitlin, much appreciated, will let you know when I am successful.
Baba
