Allocating more space in TAB theme groups
3202
04-27-2016 11:12 PM
RodWoodfordOld
Is it possible to allocate more space for grouped widgets in the TAB Theme? I would like to give 75% more space to the eSearch widget and 25% to the addlayer widget. At the moment it's split 50/50. If this is possible can anyone advice on how to do this? See screen short below.
cheers
Rod
Tags (1)
RobertScheitlin__GISP
Rod,
  This code is not flexible, it is specific to your exact scenario of wanting the first widget in the group to have 75% and the second to have 25%
In the [install dir]\server\apps\[app#]\themes\TabTheme\panels\TabPanel\Panel.js change the _setFrameSize function.
_setFrameSize: function(frame) {
        var count = this.getChildren().length + 1;
        var hPrecent;
        if(count === 1){
          query('.tab-widget-frame', this.containerNode).style('height','75%');
          html.setStyle(frame.domNode, 'height', '75%');
        }else if(count === 2){
          query('.tab-widget-frame', this.containerNode).forEach(function(node, index){
            if (index === 0){
              hPrecent = 75;
            }else{
              hPrecent = 25;
            html.setStyle(node, 'height', hPrecent + '%');
          html.setStyle(frame.domNode, 'height', '25%');
        }else{
          hPrecent = 1 / count * 100;
          query('.tab-widget-frame', this.containerNode).style('height', hPrecent + '%');
          html.setStyle(frame.domNode, 'height', hPrecent + '%');
Rod,
        var hPrecent;
        if(count === 1){
            if (index === 0){
              hPrecent = 75;
            }else{
              hPrecent = 25;
        }else{
RodWoodfordOld
Thanks Robert,
I'll give this ago and get back to you re answered.
cheers
Rod
RodWoodfordOld
Hi Robert,
Works beautifully. Thanks for your help. See link below when you can.
Bayswater Maps
I did make one change to prevent other tabs from reducing in size. If count is 1 then set height to 100%
if(count === 1){
          query('.tab-widget-frame', this.containerNode).style('height','100%');
          html.setStyle(frame.domNode, 'height', '100%');
cheers
Rod
