Add SimpleMarkerSymbol to Geocoder
4088
06-16-2015 12:13 PM
GiovanniMarrero3
I'm currently updating the Geocoder in WAB to work like the link below but I can't figure out how to add a marker when an address is found. Can someone tell me why this code is not adding a graphic after inputting an address in the geocoder?
Trigger Layer(s) Popup with Feature.Geometry
      onFindResults: function(results) {
        //Check to see if the user typed an MGRS or USNG string
        this.lastMgrsResult = this.lookupMgrs(results.results.value);
        if (null !== this.lastMgrsResult) {
          // Get reference ellipsoid coordinates of the current coordinate system
          // var mapWkid = this.map.spatialReference.wkid;
          // var srWkid = csUtils.isProjectedCS(mapWkid) ?
          //csUtils.getGeoCSByProj(mapWkid) : mapWkid;
          //Make a new object just like the objects in results.results.results
          var point = new Point(
            this.lastMgrsResult.longitude,
            this.lastMgrsResult.latitude,
            new SpatialReference({
              wkid: 4326 //srWkid   should use the ellipsoid SR of the current coordinate system
          var extent = this.map.extent.centerAt(point);
   var symbol = new SimpleMarkerSymbol();
  symbol.setStyle(SimpleMarkerSymbol.STYLE_SQUARE);
  symbol.setColor(new Color([153,0,51,0.75]));
          var graphic = new esri.Graphic(point, symbol);
   map.graphics.add(graphic);
          var resultObject = {
            extent: extent,
            feature: feature,
          //Insert at start of results list
          results.results.results.unshift(resultObject);
RobertScheitlin__GISP
Giovanni,
  1. Did you add the requires for Point, SpatialReference, SimpleMarkerSymbol, Color, Graphic ?
  2. In a WAB widget you have to use this.map and you only have map.graphics.add(graphic);
  3. You have this "feature: feature," in your code and I don't see where feature is defined anywhere.
Giovanni,
GiovanniMarrero3
Thank you for taking the time to answer this question. I had the three problems you mentioned, I was missing the "esri/Color" in the define section and I needed the "this.map." to map.graphics.add(graphic), and I had it in the wrong section of the script. Here's the working code.
if (feature) {
      var mpPt = feature.geometry;
  this.map.centerAndZoom( mpPt, 20);
     symbol.setColor(new Color([255,0,0]));
      var graphic = new esri.Graphic(mpPt, symbol);
  this.map.graphics.add(graphic);
      setTimeout(lang.hitch(this, function(){ var scrPt = this.map.toScreen(mpPt); this.map.emit("click", { bubbles:           true, cancelable: true, screenPoint: scrPt, mapPoint: mpPt }); }), 1000);
      } else if (extent) {
         this.map.setExtent(extent);
Thanks again!
