Accordion or tabs within the About Widget
2385
10-22-2019 07:38 AM
MichaelDeliberato
Hello All,
I work for a Local Government in Ohio and we are creating a parcel viewer of sorts. I have all the maps and most of the application created using WAB 2.13 but am running into a problem I cant seem to wrap my head around. We have the about widget opening on default when the application is initiated. This is where we are going to place our disclaimer as well as some text about how to use the application but wanted to make it easier for the user and put an accordion or tabs within the widget so they can click on one and see the disclaimer then click on another and see the how-to rather then jamming them all in together but cant seem to get it to work properly within the existing and out of the box about widget. Can someone help me complete either getting the accordion (preferable) or the tabs into the widget or where i can go to being to learn how to do this. I should be able to manipulate the tabs and the text after i have the framework added to the widget but cant seem to get it to work correctly.
RobertScheitlin__GISP
Michael,
  See this thread.
https://community.esri.com/thread/176252
MichaelDeliberato
Would the level of complication be the same with the about widget as well?
Yes. Both widget are taking a richtext editors text and parsing the text to html code. So they are basically the same.
