WAB - Query widget does not return result
1272
02-12-2018 12:56 PM
MarkRankin1
Hello All,
I'm using a custom WAB.  I have a service that is using the same data for three layers by having a different definition query on each layer before publishing.  When I use the Query Widget I type in the the Query criteria in the "Tasks" tab and a list of available options appears in a drop down.  I click on the record I'm interested in then click on apply and then I get a "Number of features found: 0" in the "Results" tab.  I'm confused because the query can see the record in the drop down so why can't it return a result?
I've tested separating the layers into 3 different feature classes and the query widget works fine but I'd prefer to keep all the data in one feature class so there's less room for error and less data manipulation in the back-end.
Thanks for any help.
Cheers,
Mark
