Water Utility Profiling Tool: Possible to use multiple point layers
2140
04-24-2014 07:50 AM
BatesRambow
In the config file for the Water Utility Profiling Tool, we are given the option to set a Point Layer (e.g. Manholes) to use to set the upstream and downstream ends of the profile graph.  My stormwater network is comprised of several point types - catch basins, manholes, etc.  Is it possible to choose multiple point layers to be considered by the Profiling tool, or should I do something to merge the layers prior to running the tool?
MikeMillerGIS
Esri Frequent Contributor
Bates,
   This is not supported, it currently only allows you to specify one point layer.
<Point_LayerName>Sewer Manholes</Point_LayerName>
