Water Distribution System Foundation error in collector
1246
09-26-2019 02:52 PM
DustinSellinger
We are starting to make use of the Water Distribution System Foundation, but have run into the issue with the collector app that is documented here.  Since the Solution is published from ArcGIS Pro it seems that the "Note:" in the link applies to us.  How do we reconcile this issue, while at the same time not breaking the format or upgrade-ability of the ESRI Solution?
DustinSellinger
It seems that the instructions in the technical support article are correct and do work.  But they take some time to take effect.  Unlike data that shows up almost right away, this took an hour or so before clients started being able to view errors.
DustinSellinger
