Find areas without water service.
1989
11-05-2013 05:11 AM
AleydisG__Pere
I'm a bit lost with this as I'm relatively new using geometric networks. And right now I only have access to an ArcGIS Desktop Basic license so I cannot test anything. But still I'm trying to figure out how to do some tasks anyway.
I would like to check the areas in my water network where customers would not have water service because the mains are not connected to a well. How should I do this? Should I define my wells feature class as a source and run the Connection Checker tool? As simple as that? Would that highlight all mains not connected to a well? And what if I also want to take into account all breaks in my water netwok?
Thank you in advance.
AleydisG__Pere
Checking the Water Utility Network tools online help I see that the Valve Isolation Trace tool maybe would do this. Am I right?
The tool description says it "Identifies all valves on a geometric network that must be shut off to isolate a section of main." But the information about configuring the tool says "The Valve Isolation Trace tool tests whether a valve is connected to a water source."
It's a bit confusing.
MikeMillerGIS
Esri Frequent Contributor
It returns only valves that need to be closed.  To do this, it barriers all other valves returned by a find connected trace and then traces from each valve to the water sources to make sure there is a path to it.
