Attribute Assistant using expression wild card
1150
02-18-2021 11:11 AM
Labels (2)
VanessaSimps
I have been tasked with populating two different fields from a single field. My plan was to use AA and either the Field, Field Trigger, or Expression function to populate the new fields.
Field where the values are added = FACILITYID
new Field 1 = FunctionalLocation
new Field 2 = EquipmentID
I plan to create two new entries into the Dynamic Value table
To populate the FunctionLocation field:
  • Table Name: swFacility
  • Field Name: FunctionLocation
  • Value Method: (unsure if this should be FIELD TRIGGER, FIELD, or EXPRESSION)
  • Value Info:
  • IIF([FACILITYID] LIKE 'E-MA%') &[FACILITYID]
To populate the EquipmentID field (this is a numeric field that is not consistent so I can't really wild card it) :
  • Field Name: EquipmentID
  • Value Info:
  • IIF([FACILITYID] NOT LIKE 'E-MA%' OR IS NULL) &[FACILITYID]
I found a few other threads where they were using similar IFF statements, but none were using a wildcard in the expression.
Thanks in advance!
