Attribute Assistant - Timestamp question
4581
13
02-06-2017 09:51 AM
TimWitt2
Hey everybody,
I am trying to get my timestamp in a certain format: YYYY-MM-DDThh:mm:ss.s but I am not able to do it.
As an example it needs to look like this: 2017-02-20T23:16:45.7
Is this even possible? If so, what would be the expression I need?
Tim
TimWitt2
Row Info
Row Number 20
TableName: *
FieldName: DateUpdate
ValueInfo: DateTime.Now.ToString("yyyy-MM-dd HH:mm:ss")
ValueMethod: EXPRESSION
On Create: 1
On Change: 1
Checking for Subtype Restriction
Field Name: DateUpdate was found at index: 68
Trying: EXPRESSION
Checking to verify there is a field to store the expression
Expression to be eval: DateTime.Now.ToString("yyyy-MM-dd HH:mm:ss")
ERROR: evaluating the expression for feature in Brevard_Nena_Street with OID of 42394
Object required: 'DateTime'
Finished: EXPRESSION
MikeMillerGIS
Esri Frequent Contributor
Using your value info through the debugger, I get a proper date and the process completes
>? args[0]
>? DateTime.Now.ToString(args[0])
"2017-02-07 14:08:04"
What version are you using? I would suggest trying out the preview of the next release
https://github.com/Esri/local-government-desktop-addins/tree/dev/PreviewBuilds
Also, you need a string field as the date/time field will display the date based on your system date time formatting.
MikeMillerGIS
Hold on, why are you using this in expression? Just use the TIMESTAMP value method and yyyy-MM-dd HH:mm:ss as the value info
TimWitt2
Michael thanks for the help. What I will end up doing is create a DATE field and a TIME field and then write an expression for my DateUpdate field looking like this: [DATE] & "T" & [TIME] & "-05:00"
