Where is XMLViewEdit.exe???
4615
01-27-2016 07:37 AM
AmandaHall1
I am having trouble with setting the default vector target location type on ArcHydro,specifically, I'm having problems with the step Editing the XML on the disk. I can't seem to find the file XML ViewEdit.exe. Do you know where this file might be located? I'm on page 11 of my ArcHydro Tutorial.
Amanda
Tags (1)
GyörgyKerezsi
 Browse to the ArcHydro\bin location (Defaults to C:\Program
Files\ESRI\WaterUtils\ArcHydro\Bin).
 Drag the file ArcHydroTools.xml onto the file XMLViewEdit.exe.
 Navigate to the node HydroConfig/ProgParams/LocationType>Vector.
 Right-click Vector and select Edit Text.
 Set the value to 0 (mdb). 1 is for gdb. Click OK. Click Save twice to keep your changes
and then close the XML Viewer.
ChristineDartiguenave
It is now called ESRI.APWR.ApXMLViewEdit.exe and you will find it under C:\Program Files (x86)\Esri\WaterUtils\ApFramework\Bin
Christine Dartiguenave
Esri Water Resources Team
GyörgyKerezsi
Thank you very much! .
I was so upset about it! But now thanks to you I am trying it again!!!
Marry me and I will never look  at another horse!  ❤️
Christine Dartiguenave <[email protected]> ezt írta (időpont: 2018. nov. 9.,
P 20:48):
GeoNet <https://community.esri.com/?et=watches.email.thread>
Re: Where is XMLViewEdit.exe???
reply from Christine Dartiguenave
<https://community.esri.com/people/cdartiguenave-esristaff?et=watches.email.thread>
in Arc Hydro - View the full discussion
<https://community.esri.com/message/812242?commentID=812242&et=watches.email.thread#comment-812242>
