Watershed Delineation using Hec Geo HMS
13254
12
07-12-2013 08:57 AM
AjayMore
Hello all,
I am trying to delineate watershed using HEC Geo HMS extension in Arc Map and watershed delineated is less than original extent and size of watershed. I loaded a polygon file of my actual watershed to the watershed generated by Geo HMS, but after that I am not getting how to proceed with Geo HMS to create the required data frame.
Any help will be highly appreciated.
Thanks very much.
Ajay
MarkBoucher
Honored Contributor
I looked closely at Ajay's image. In the upper right portion, there is a stream that goes outside of the watershed boundary. This is likely the problem.  See the attached close up of the spot the creek leaves the boundary. If you modify your boundary to include the stream, things should get better. All your grid data (fdr, rawdem, str, strlnk, etc...) need to be inside the boundary also.
I once had a creek that went right up to the edge of a watershed. In the processing creek would end right near the boundary. I think it is because the burning streams lowered the DEM at the boundary and then the flow direction grid naturally choose that as the outlet. The solution was to use an "outer wall". This is likely what is needed here.
One problem could be with the "polygon file of [your] actual watershed"(1).  In the hydrology geoprocessing, nothing is the "actual watershed". The DEM is a discrete grid. If you look close at the streams generated, they go from grid center to grid center. The watershed boundary's do the same. This does not follow the "actual" feature (stream or ridge). So, if you try to superimpose an "actual watershed" on the grid, you need to consider that the polygon you bring in may not line up just right with the DEM.
[ATTACH=CONFIG]26070[/ATTACH]
(1)This assumes that I understand what your doing with the "actual watershed". Did you load your "actual watershed" just for comparisons, or did you load it to use it in the processing (Batch Watershed Delineation for Watersheds)?
MarkBoucher
Honored Contributor
An attached image instead of an imbedded one.
AjayMore
After a lot of efforts and thanks to all you guys for helping me out, esp. Mark Boucher.
I am really thankful for your detailed reply and I apologize for replying so late.
The problem was the threshold of Agree DEM, since my threshold was high, stream network got disconnected and hence my watershed was only upto the point of disconnect. lowering threshold solved my problem.
Cheers !!!
Ajay
