Turn Off ArcHydro Target Workspace Auto-generation
3136
10-08-2014 09:05 AM
by Anonymous User
Not applicable
I'm using ArcHydro 10.1 beta and ArcGIS Desktop 10.2.2. I want to disable automatic creation of target workspaces as described in the ArcHydro help:
"If you are not using the Arc Hydro tools and want to prevent the target location from being automatically created when saving a new map document, you can switch off the automatic creation of the target dataset (and associated Arc Hydro Configuration file - *.ahd file) by changing the value of the parameter HydroConfig/ProgParams/CreateGPConfigOnSave from 1 to 0 in the XML configuration file on the disk (i.e. ArcHydro/bin/ArcHydroTools.xml)."
I've found and searched through ArcHydroTools.xml but it doesn't contain a node named CreateGPConfigOnSave. Was the structure of this XML file updated without updating the docs? If so, can anyone point me to the new location of the parameter that controls auto-creation of target workspaces? Any help would be appreciated.
Dave
