Raster analysis following flow direction
1790
02-11-2013 01:50 AM
MiguelLlorente_Isidro
Hello,
I am trying to obtain a raster dataset out of this analysis: for each pixel in a raster I want to substract value of the previous pixel according to the flow direction.
Lets say pixel A flows into pixel B. Pixel A has a value of 3 and pixel B has a value of 4. I'd like to get a raster where in pixel position of B I have a value of 1. For all those pixels where there is no previous pixel flowing into it, it should return a value of 0.
Any thoughts? Thx!
MarkBoucher
Honored Contributor
I commented on another thread where the user wanted to analyze the values around a grid cell.  I found the "Shift" tool. http://forums.arcgis.com/threads/75804-surface-angle-in-each-cardinal-direction?p=265962&viewfull=1#...
You might be able to do the same by instead of just the 4 directions (N, S, E, W) that this user was wanting to deal with, you could make fdr grids for each of the 8 directions. Then use the the Con() function with the flow direction grid as the test to determine which of the 8 grids to do the math with. The logic is probably simple and model builder could make it easy to via trial and error.
Hello MBoucher21, thx for your uberfast reply.
I was getting "range" out of Focal Statistics with a 2x2 neighbourhood applied solely to the river network and I was having some inconsistencies due to river proximity. Your suggestion worked like a charm.
Regards,
