Merge two raster files with overlap
2829
03-02-2020 05:27 PM
pouyakhalili
I am trying to merge two raster files which have overlap at some points. One of the raster files has higher resolution and the other has a lower resolution. I want to merge them in a way to keep the higher resolution raster file and fill the rest with the lower resolution raster file. Attached you can find images of my raster files. Merged.jpg is what I expect to get. I would appreciate your help.
Pouya
ShaneMiles
Hi pouya khalili‌,
Check out the Mosaic Rasters function—ArcGIS Pro | Documentation and if this does not help  the Raster functions—ArcGIS Pro | Documentation. In the mosaic raster function you could select First as the operation and ensure your Higher resolution image is the first input. I hope this helps answer your question.
Shane
