Measuring stream channel distances
2371
10-31-2013 01:57 PM
PamFroemke
Hello all,
Not sure I'm in the right place to ask this question. I need to determine stream channel distances as part of a surface water quality study. For example, calculate the distance upstream from a stream gauge to many various other points (land use types, point discharges, etc.) so that I can relate the water quality data collected at the stream gauge to what's happening in the upstream watersheds.
I don't see obvious tools in ArcMap's regular toolboxes that could do this. Does Arc Hydro perform these sort of functions?
Thank you,
Pam
MarkBoucher
Honored Contributor
MarkBoucher
Honored Contributor
This might be the same question you have. http://forums.arcgis.com/threads/46124-Upstream-distance-DEM
PamFroemke
Thank you so much!! This looks like it may work for my project.
