Is there Archydro tool for arcmap 10.4 version?
20299
14
04-04-2016 06:23 PM
MarinaLaus
Hi, I have downloaded the arcgis version 10.4 and I need the Archydro tool to work on it. Does anyone knows if there is a version of archydro for arcgis 10.4? Or do i need to download other version of Arcgis? I thought wierd because I got Arcgis from free trial on esri and they gave me version 10.4 and for other friends who did de same, other versions. Thank you!
ToddMcDonnell
Thanks Stuart. Do you know why the most recent version (10.4.0.24) is dated later than version 10.4.0.3?
V_StuartFoote
Hmm, it is not.
10.4.0.24 was built/posted 2016-12-27, 10.4.0.3 was built/posted 2016-06-02--simply that the sort order on the web page is *not* by date. Rather it is an ASCII sort of the folder name--last column is the version and 24 comes before 3.
KurtisBaron
Does anyone have an Arc Hydro version 10.4.0.17.  I don't find it on yellow.esri.com and my Geo-HMS installation is asking for it.
Kurt
ChristineDartiguenave
GeoHMS should install Arc Hydro if it is not already installed. Can you try to uninstall GeoHMS, Arc Hydro and reinstall GeoHMS only?
Christine
Christine Dartiguenave
Esri Water Resources Team
KurtisBaron
Thanks Christine,
That’s the way I usually installed it. At my current job we have to work with IT do get anything done, which is lots of fun. I don’t see either application in Add/Remove Programs (now “Programs and Features”), but I’ll work with IT to navigate through the process.
Thanks for your continued support!
Kurt Baron GISP
Senior GIS Analyst II
Public and Private North America
Engineering Design and Project Management
<http://www.atkinsglobal.com/>
