HEC-GeoRAS Floodplain Delineation error (cross sections updated in HEC-RAS)
6858
12-17-2013 11:44 AM
DonghaKim
Hi Folks,
I am using ArcGIS 10.1 and HEC-GeoRas 10.1 I am able to create a GIS project, export all data to HEC-RAS. The first issue was that cross sections GeoRAS created were not in good quality so I updated them by measured bathymetry data. That is, replace the values of station & elevation in Geometric data window in HecRas by the bathymetry data. Subsequently, it is likely to bring up a task of updating the original TIN used to create the original cross sections in GeoRAS to reflect the changes.
Then, I run my steady simulation, and imported back into ArcGIS just fine. I then covert SDF to XML, set up my layer, import the RAS data (coordinations of the updated cross sections matches well with those of the original on GIS) , and do a water surface generation. However, on this last step, the program crashes with the following error:
System.Runtime.InteropServices.COMException(0x80041098):ERROR 010151: No features found in C:\........\Steady_PF\fdtemp.shp. Possible empty feature class.
at ESRI.ArcGIS.GeoAnalyst.RasterConversionOpClass.RasterDataToPolygonFeatureData(IGeoDataset dataset, IWorkspace pWorkspace, String name, Boolean weeding)
at HECGeoRAS.clsMFloodGRIDIntersection.GridToPolygon1(IRaster pRaster, IGeoDataset pGeoIn, IWorkspace pWS, String sName, Boolean sWeeding)
My guess about the causes of this error are:
1) As mentioned earlier, I updated the GeoRas-created cross sections in HEC-RAS so GeoRAS might have a conflict on matching the original cross sections with the updated ones. Any solutions? How can I edit TIN to incorporate this change?
2) GeoRAS uses a unit of meter and HecRAS uses feet. Does this somehow affect floodplain delineation?
Any suggestions, especially detailed ones, would be greatly appreciated.
Dongha
Syr91
Hi Dongha Kim!
I have exactly the same error and I can´t solve it, and I'm going crazy.
Did you solve the problem? If you solved, can you share it with me?
Thank you so much!
EstefaniaGarcia
Hi  Dongha Kim and syr911,
Guys I have the same error and I can´t solve it, I don't know what to do, I had try everything.
Did you solve the problem? If you did, can you share it with me please?
Thank you so much!
