HEC-GeoRAS Export RAS Data - empty message window
1398
03-02-2017 06:07 AM
MartaLustyk
I just start working with HEC-RAS and I've got problem with export my ESRI files to RAS. I do complete pre-processing in ArcMAP 10.2.2. (I use HEC-GeoRAS 5.0.3) and everything was great until I have to Export GIS data to RAS: Export RAS Data. When I click OK ExportRASData window is empty like below:
Obraz w treści 1
Due to I can't continue work in HEC RAS, because I have no files to import.
Before, I pre-processed data by tutorials on youtube  and paper tutorials and I have got the same problem on the same step. When I check data in attribute tables in feature classes according requires in tutorial  for me everything is fine.
Have You got any advices where is the problem or what where I do mistake?
More screens from my project:
XSCutLines3D
(I know that it it should be drawn more precisely, but I did it so many times and never work, so now I just want do achieve correct export.)
Regards,
Marta
