HEC GeoRAS 10.2 Import Error
3296
07-08-2015 03:36 PM
ShannonQualie
I used Hec-GeoRas to create a simple drainage path and cross sections on an elevation raster.
  1. Exported to Hec-Ras 4.1.0.
  2. Analyzed it and exported the results to SDF.
  3. Converted the SDF to XML.
  4. Tried to import the XML back to Hec-GeoRas
  5. Import failed (see screen shot pic)
Google seems to be telling me this is a somewhat uncommon error (?) and that the only solution is to go back to  Arc 9.3 and Hec-GeoRas 4.3.
I have tried creating a personal GDB instead of a file GDB. This didn't work.
Does anyone have  any suggestions for what (no doubt obvious) step I am missing?
Is it the SDF that is wrong?
Thanks for your help.
Shannon
Message was edited by: Shannon Qualie Thought it might be a good idea to add the SDF too.
Message was edited by: Shannon Qualie Problem solved - This is a Windows 8 problem. My data and sample data refuses to run on Windows 8, runs flawlessly on identical set up in Windows 7.
