Hec-GeoRas 10.1
4160
11-06-2012 08:33 AM
TonyHowze
Will there be an update of Hec-GeoRas for ArcGIS 10.1?  I have upgraded to 10.1, but am now at a loss because I no longer can use GeoRas.  This is detrimental to my company.  Any information will be appreciated.  Thank you.
EdMaurer
I also just upgraded and now GeoRAS and GeoHMS won't install because they look for v. 10.0. Is there a simple solution for this?
V_StuartFoote
Not clear when or if the USACoE HEC will have a requirement for support of ArcGIS for Desktop 10.1, and contract with Esri to develop that capability.  So, unfortunately, no easy fix.
You will either need to roll back to ArcGIS 10.0 to use HEC-GeoRAS and GeoHMS, or make do with using ArcHydro and Spatial Analyst scripting to preprocess your spatial data for use in HEC-RAS or HEC-HMS.
Stuart
V_StuartFoote
Esri Water Resources team has reworked the community ftp service site.  It is now a hosted secure file transfer service.
We just moved to a new ftp server system:
https://mft.esri.com
Login: ADSRiverHydraulics
Password: ADSRiver.2012
Note that the password will be reset every 6 months or so.
To access, select a FTP client:
1. Web Client
   Site link:  https://mft.esri.com
   (Video tutorials available on the main page, prior to log in)
2. Third party SFTP client
   ** Download a preconfigured client
https://mft.esri.com/EFTClient/Account/mft.zip **
3. FTP address to configure a third party SFTP client of your choice:
   Site address:  mft.esri.com
   Port:  22
Christine Dartiguenave
Esri Water Resources Team
You'll find beta builds of the HEC GeoHMS and GeoRAS for use with ArcGIS 10.1
Should be stable, but mind your Python configuration when installing, please report bugs and check frequently for patched builds.
Stuart
