Generate CN grid error
1419
05-16-2012 05:32 AM
FaidessMwale
Hie,
I want to generate a curve number grid using HEC-GeoHMS 5 which I just installed. I have arcmap 9.3.1 and  archydro 1.4. Whe I use the Generate CN grid tool, I get an error that says
" Aplayer is not defined for .... Run Create  ArcHydro configuration function and try again".
the layers am using were generated using archydro 1.3 which I uninstalled. I added the ArcHydro tools to arctool box and when i open it, there is no "create  arc hydro configuration function" nor does ArcHydro settings appear in the environment settings. This is contrary to ArcHydro GP Tools 1.4 Tutorial.
Any help please?
Thank you
