Exception from HRESULT: 0x80040215 error when Executing Longest Flowpath
8722
04-01-2016 02:54 PM
MattKitchen2
Hello all,
I am attempting to worth my way through using ArcHydro and HEC-GeoHMS.  All has gone smoothly until now.  I have tried to change about every setting in the world that I can think of, but to no avail. I have also tried the "ArcHydro Problems Solvers" seen in another thread.  Below is the full test of the dialog box:
Executing: LongestFlowpath FullDEM3.tif Fdr Subbasin1 "C:\Users\Matt\Desktop\Floodplain Testing\Flowpath.mdb\LongFlow421"
Start Time: Fri Apr 01 16:48:43 2016
Executing: CreateFeatureclass "C:\Users\Matt\Desktop\Floodplain Testing\Flowpath.mdb" LongFlow421 POLYLINE # DISABLED DISABLED # # 0 0 0
Succeeded at Fri Apr 01 16:48:43 2016 (Elapsed Time: 0.16 seconds)
Creating zone raster from drainage area polygons
Computing flow length
Computing maximum flow length
Executing: CopyRaster C:\Users\Matt\AppData\Local\Temp\arc412F\AH20160401164844\ras2865 C:\Users\Matt\AppData\Local\Temp\arc412F\AH20160401164844\tmp25D5 # # -3.402823e+038 NONE NONE # NONE NONE
Start Time: Fri Apr 01 16:49:05 2016
Succeeded at Fri Apr 01 16:49:06 2016 (Elapsed Time: 1.03 seconds)
Executing: RasterToPoint C:\Users\Matt\AppData\Local\Temp\arc412F\AH20160401164844\tmp25d5 C:\Users\Matt\AppData\Local\Temp\arc412F\AH20160401164844\AHTemp.gdb\tmp249B Value
Start Time: Fri Apr 01 16:49:06 2016
Succeeded at Fri Apr 01 16:49:07 2016 (Elapsed Time: 0.66 seconds)
Computing flow path from the maximum flow length points
Creating flow paths...
-49602 Error in ComputeLongestFlowPath System.Runtime.InteropServices.COMException (0x80040215): Exception from HRESULT: 0x80040215
   at ESRI.ArcGIS.Geometry.IRelationalOperator.Contains(IGeometry other)
   at ESRI.APWR.ApHydro.ArcHydroOp.ComputeLongestFlowpath(ApLayers apLayers, Int32 debug, ITrackCancel& trackcancel, IGPMessages& messages, String& exMessage, IRaster costRaster) in C:\Builds\HydroSolutions\10.3_ArcHydro\Sources\ArcHydroTools\src\ApHydro\ArcHydroOp.vb:line 49516
Failed to execute (LongestFlowpath).
Failed at Fri Apr 01 16:49:09 2016 (Elapsed Time: 25.72 seconds)
Any ideas?
Thanks!
DanPatterson_Retired
all links to that error message eventually come back to recommends to seeing the archydro problem solving thread... a common issue is file locations, path structure and network stuff.  have you tried to simplify the locations of the input and output data and ensure simple compliant paths (ie no spaces etc)
