Error Trapping: ArcHydro LongestFlowPath
2995
05-20-2013 09:38 AM
PeterWilson
I've a very large model where I'm processing 650 watersheds. My model is failing when trying to generate the longest flow paths for the 650 watersheds. I would like to trap the individual watersheds that are causing the longest flow path to fail, report the hydroID and continue the the rest of the watersheds at least. I can always go back to look at the watersheds that throw an exception to see whats causing the the tool to fail.
import arcpy, ArcHydroTools
watshed = r'E:\Projects\H109355_2\ArcHydro\Model3\Nigeria03.gdb\Layers\Watershed'
fdr = r'E:\Projects\H109355_2\Archydro\GRID\layers.gdb\Fdr'
ArcHydroTools.LongestFlowpath(watshed,fdr,r'E:\Projects\H109355_2\ArcHyro\Model3\Nigeria03.gdb\Layers\LongestFlowPath')
I've tried the following approach, but over write output doesn't work:
outpath = arcpy.env.workspace = r'E:\Projects\H109355_2\ArcHydro\Model3\Nigeria03.gdb\Layers'
fdr = r'E:\Projects\H109355_2\ArcHydro\GRID\Layers.gdb\Fdr'
watshed = "Watershed"
with arcpy.da.SearchCursor(watshed,("Name",)) as scur:
    for row in scur:
        cuindex = row[0]
        sqlexp = """{0} = '{1}'""".format(arcpy.AddFieldDelimiters(watshed,"Name"),cuindex)
        watshedind = arcpy.FeatureClassToFeatureClass_conversion(watshed,outpath,"watshed",sqlexp)
        try:
            longflowpath1 = ArcHydroTools.LongestFlowPath(watshedind,fdr,"in_memory\longestflowpath")
        except:
            arcpy.AddMessage
            print cuindex
Any help will be appreciated.
Regards
ChristineDartiguenave
We have modified the function so that it now runs through all selected input features and report the issues at the end (10.1.0.160). Give it a try.
Christine
Christine Dartiguenave
Esri Water Resources Team
PeterWilson
Thanks Christine
Appreciate the following, I'll rerun the following section and let you know.
Regards
