Assing Unique ID
1972
6
01-27-2013 12:23 AM
An_HoTaylor
I know this is a really stupid question, i been following a groundwater geodatabase tutorial with archydro 1.x (http://www.growe.ksu.edu/Groundwater_Data_Models/Feflow_2/KonzaFeflowTutorial.pdf) i'm utilizing archydro 2.0 (arcgis 10) so i can't find Aputilities---assing UniqueID option, maybe the menu is different between versions, so i can't figure out how to realize this step, would you mind telling me how  activate this option or why  there is not this option in this version or further information, i really appreciate this
MarkBoucher
Honored Contributor
Add the Arc Hydro Tool Bar. ApUtilities is near the right end of the bar.
An_HoTaylor
i did it, but i still can't find the assign unique ID option in the arc tool bar version 2.0 (arcgis 10). 😞
MarkBoucher
Honored Contributor
Assign UniqueID is in the Arc Hydro Tool Box. Maybe they took it off the toolbar for some reason.
ChristineDartiguenave
If you are using ArcGIS 10, I would upgrade to Arc Hydro 2.1. Assign UniqueID is still in the ApUtilities menu in versions 2.1 (ArcGIS 10) and 10.1 (ArcGIS 10.1) for sure. We added it to the toolbox but did not remove it from the toolbar.
Christine Dartiguenave
Esri Water Resources Team
MarkBoucher
Honored Contributor
Related thread. They say 2.1 is not out for 10.1 yet. Is this true?http://forums.arcgis.com/threads/76951-Missing-Flow-Direction-with-Streams-tool-in-10.1-BETA?p=27052...
I looked on the ftp site and the names of the folders in the 10.1 folder don't call out the ArcHydro version. Their named "ArcHydroTools10.1" with no version indicated. I'm using 10.0 so wouldn't matter to me yet.
MarkBoucher
Honored Contributor
Upgraded to 2.1 and now have the Assign UniqueId option. Thanks!
