Splitting a Route into segments between orders/stops
3782
04-23-2015 08:39 PM
JoelSamelson
I have a routes layer from Network Analyst's Vehicle Routing Problem, and want to split a route into segments connecting each of the stops to calculate the distance/time/cost for each route portion.
I already tried using the "Split Line By Point" tool, but this seems to cause false segment breaks when a route doubles back on the same road past a stop. Is there a way to do this? Thanks!
MaximeDemers
I know this is an old post, but I have the same question.
Have you found a solution?
