Report maps
1330
12-02-2010 05:05 AM
LarryWilliams
Using 9.3.2
How do you add a map to a report? Looking at the existing Crystal report files it appears that the maps are blobs and I've picked up enough to know that this is added by inserting an OLE object but what object do you insert?
What I'm trying to do is to zoom in on the existing map but when I enlarge it the result is a pixellated image of the map.
JeffWickstrom
Larry,
Did you get this figured out?  What you need to do is drag that StopVicinityMap field from the RouteDetail table onto the report.  Or the OverViewMap from the Route table.
Jeff
LarryWilliams
This doesn't explain how I can zoom into the map.  If I try doubling the size of the StopVicinityMap it only pixelates the graphic of the map.
Are there only the two types of maps available?  IE I have to copy them from an existing report.
