Python Calculate Field If Statement
17778
14
02-14-2011 10:57 AM
Ryan_Galbraith
Just wondering if the Python-Geoprocessing Community could help me.  I am trying to write the following code block into a calculate field called weight from the values in another field called Symbol.
def Reclass( !Weight!):
  if ( !SYMBOL! == 6):
    return 1.2
  elif ( !SYMBOL! == 85):
    return 1.5
  elif ( !SYMBOL! ==2):
    return 1
  elif ( !SYMBOL! ==42):
    return 1.8
  elif ( !SYMBOL! ==58):
    return 2
It just won't work.  help...
by Anonymous User
Not applicable
Original User: niklas.norrthon
I tested it and got the same error, and I still don't understand why. But I found an easy workaround: Rename the dictionary to something else (without underscore) like symweights. Do that both in the code block and the expression field and it works.
Ryan_Galbraith
That works perfect.  Like Python should!  Amazing.  I choose this method, because I wanted to use the ModelBuilder.  Not sure if a cursor would work in this case.
by Anonymous User
Not applicable
A cursor would work just as well (untested):
symbol_weights = {
    6: 1.2,
    85: 1.5,
    2: 1.0,
    42: 1.8,
    58: 2.0,
cur = arcpy.UpdateCursor(my_feature_class)
for row in cur:
    row.Weight = symbol_weights[row.SYMBOL]
    cur.UpdateRow(row)
Ryan_Galbraith
Cursor works better!
AndyOmmen
Hi Ryan,
When you define the method within the Python codeblock, use a variable for the Reclass method's parameter and use that variable within the method's logic:
def Reclass(weight):
  if (weight == 6):
    return 1.2
  elif (weight == 85):
    return 85
Then when you call the Reclass method in the Calculate Field Expression parameter, you will then pass in the SYMBOL field:
Reclass(!SYMBOL!)
