Problem with projecting from WGS to Spherical
1051
03-26-2013 09:21 AM
TunagginaKhan
Hi all
I am having a problem with projection but not sure which sub forum I should post it to, s posting it to this forum. Any solution for my problem is really appreciated.
I wanna re project a shapefile from WGS 1984 to a spherical projection (any valid spherical projection for the North America will work) but the geographic transformation does not work. It rejects every option (transformation from the drop down menu in geographic transformation box) when I am trying to project (data management--projection--feature--project).
Thank you so much
Subrina
