Need some Python code for field calculator!
5259
6
12-02-2013 04:16 AM
by Anonymous User
Not applicable
Original User: jofuchs
Hi all!
I am a very beginner with Python, so that will be an easy task for most of you. 🙂
I want to calculate a new field of an attribute table, something like that: ((Field X/ Field Y)*100). Since 0-Values are existent, I have to exclude these values from dividing.
What I tried so far is displayed in the screenshot, but doesnt word untill now... (Perhaps it is totally wrong...)
[ATTACH=CONFIG]29480[/ATTACH]
I hope you can help me! Many Thanks in advance!
Jo
AnthonyGiles
Honored Contributor
I have created a sample feature class with three columns a,b and c. A and B are Long and C is a double. The code in the attached screenshot works fine:
[ATTACH=CONFIG]29490[/ATTACH]
Try changing your square brakets in your expression to normal brackets ()
Regards
Anthony
by Anonymous User
Not applicable
Original User: [email protected]
Jo,
Try this:
def calc(f1,f2):
  if (f1 <> 0):
    return (f1/f2)*100
  else:
    return 0
Regards
Anthony
by Anonymous User
Not applicable
Hi Anthony,
thanks for your reply. There is still this error message appearing
[ATTACH=CONFIG]29484[/ATTACH]
For your information:
The field i am calculating is double formatted; f1 and f2 are long integer. But I think thsi should be ok so!?
Jo
AnthonyGiles
Honored Contributor
Jo
It looks like you have zeros for both columns, try
def calc(f1,f2):
  if (f1 <> 0 and f2 <> 0):
    return (f1/f2)*100
  else:
    return 0
by Anonymous User
Not applicable
I corrected this, you are right. That might be another potential error, but nevertheless I always have the same error message posted before...
EDIT: Field f1 is long, field f2 is double, target field is double! Can this be a problem?
AnthonyGiles
Honored Contributor
Regards
Anthony
by Anonymous User
Not applicable
Anthony
Thank you very much! That worked fine!
