default symbology
3571
03-29-2013 01:44 PM
ScottOatley
Hi Folks,
The following arcpy script adds a raster image to the TOC:
import arcpy
mxd = arcpy.mapping.MapDocument("CURRENT")
df = arcpy.mapping.ListDataFrames(mxd)[0]
r = arcpy.mapping.Layer('C:/myimage.sid')
arcpy.mapping.AddLayer(df, r, "TOP")
It adds images successfully but defaults them all to an unacceptable symbology.
[ATTACH=CONFIG]23085[/ATTACH]
[ATTACH=CONFIG]23086[/ATTACH]
Any suggestions on how to get the images to load with appropriate colors, i.e. grey scale or rgb?
Scott
ChrisPedrezuela
Hi Scott,
I think you can just opt to create a LYR file for raster with correct symbology then just change datasource manually or thru python.
Cheers,
Chris P
