An invalid SQL statement usec
3609
05-10-2011 06:19 AM
BradClay
Invalid SQL statement used - I get this error when moving orders from one route to another route and the movement from one route to the other fails.
BertYagrich
Not sure about this one without more info.  Could you give some detail as to why the order move fails?  Maybe a screenshot or two might help.
BradClay
This error also appearing with some solves, success with solving some selected groups of orders and not others. When this error appears with a solve there is no pop box with the usual explanation of reasons why the solve did not work. Is there an error log that I can see to explain this? Ideas?
BertYagrich
Unfortunately, there are no logging capabilities.  I think we'll probably need to have a look at the project if you don't mind sending it over.
Are you evaluating the software or have you already purchased?  If it's the latter, the best bet is to call tech support and get an incident logged for this.  If you're in the evaluation phase, send me a note at [email protected] and we'll work something out.
BradClay
yes, already own the software, alright, I will write a support ticket.
