Re: Ericsson's Network Engineer (ENE) and Esri
11208
14
04-03-2018 10:56 PM
RajeshMane3
Hi Greg,
We are in process of upgrading our desktop system on 10.x. We are actually using Ericsson's Network engineer and planning to replace it with ArcGIS pro and subsequently web and mobile.
Before moving further, I would like to know following things in order to support our datamodel in ArcGIS Pro. As current datamodel is in geometric network and needs to be migrated in Utility Network.
  1. Can we use same table structure as presently getting managed in Ericsson network engineer.
  2. If not then , How utility network will manage following things in its datamodel.
  • Cable Units
  • Structure Units
  • Span Units
  • Equipment Details Views
  • Structure , Span details views
  • connections of Equipment and cable
  • Network traces required for Port to port tracing
Can we get this information in esri's datamodel which supports utility network ? When esri is planning release complete solution of telco datamodel and its required extension of Network utility configuration would be released ? As did not find any write-up or white paper written on Telco Utility Network model as similar to electric , water and gas.
appreciate for your response to move further.
Regards,
Rajesh Mane
Solution Architect
British Telecom , PLC
bhaveshpatadiya
Hi Rajesh,
You started a great discussion. We are also looking for something similar to this.
Hi Patrik,
I am an active user of ArcGIS pro and Enterprise and seeing the performance, would be really interested in the solution. I shall send you our concerns on the cited email ID.
UmairSiddiqui
Please contact us for complete Network Inventory solution - Esri based NetDesigner [email protected]
Enghouse Networks Releases NetDesigner 6.4 on the ESRI ArcGIS Platform | Enghouse Networks
RajaIjazHaider
Fiber Utility management System (FUMS) is best fit for ENE replacement, its dataset is similar to ENE and carry all functionalities which are in ENE, plus many more advanced features. Solution is ArcGIS Pro enabled as well ESRI Enterprise 11 complied. Solution is available for On Premises as well as Cloud. Visit Story Maps at https://enterprise.sitdigital.com/storymap
fahad_rasheed
Hi Guys
If you are also trying to replace ENE, ND, ArcFM or anyother outdated (ArcMap) based fiber management tool and looking for a better more customized solution click the link given below.
RajaIjazHaider
