Hello Community Members,
While applying the asset package on CommunicationsUtilityNetworkFoundationV1_1, I am getting the following error. The previous stage of the utility network geoprocessing run was successful.
I am using the ArcGIS enterprise 10.9.1 version ,
Asset package : CommunicationsUtilityNetworkFoundationV1_1
ArcGIS Pro: 2.9.10
Python package Untools: 2.9.7
Can anyone highlight what might be the issue here?
Solved! Go to Solution.
@RajAlva00 I have created another Py clone, and restarted ArcGIS (pro 3.1), and I found the Asset Package loaded into the Utility Network, despites all the error I got earlier.
Apparently, rebuilding the Py environment solves it.
Thank you @SpatialNinja
Have you tried to re-build your python environment clone?
Can you attempt again without any maps open in the project?
Have you also put in a support ticket?
@RajAlva00 Was it resolved? I've been into the same error (well.. and thousands others). I tried closing the maps but didn't help, I wonder if you tried to rebuild the Py environment.
Once I get to the same error again I'll reply with any updates I get.
