Communications Utility Network Tracing
1292
12-27-2024 06:25 AM
buddhimadusanka1
Hello,
I have deployed the Communications Utility Network Foundation and tried to perform a trace. It only works when the starting point is marked on Communication Junction objects. When I attempt to mark a Communication Device or Junction as the starting point, the trace fails, and I receive the error: "No valid subnetwork controllers found."
Is there a way to enable tracing from a Communication Devices or Junctions?
Thank you.
SpatialNinja
Which trace are you running? One of the pre-configured traces in the foundation or your own trace configuration?
Solutions Engineer | Spatial Ninja  | GIS ️ | Telecommunications
