Spatial Share Testers on Vision Pro
738
01-05-2026 11:10 PM
youknowww
Trying out a simple app for collaborating to on a map view in an Immersive Space on Vision Pro. Not ready for prime time but I'd love to prototype Spatial Share. I don't know a single other person with one irl. Anyone in the community have one and want to test Spatial Share on my app? I'll return the favor if you want the same or want TestFlight feedback. Planning to ask our ESRI support rep if ESRI's willing to share a tester but my expectations are low since this is only a for-fun project on practically obsolete hardware
I'd like to record the session but can be flexible if anyone is uncomfortable with that
Nicholas-Furness
Just FYI for anyone else reading this, @youknowww and I have been chatting in a DM thread about some of his prototyping.
We're always interested in hearing more about how you're using Vision Pro with Esri tech, so I encourage people to reply here or post in the Swift Maps SDK Questions forum if you have questions or just want to share what you're doing.
youknowww
Here's a video of the current prototype and an open source repo for anyone interested:
https://codeberg.org/youknowww/MapSpatial
https://www.youtube.com/watch?v=TNVwqVYCI6I
The novel part is the gaze-based hover/reticle for select.
Turns out after some recent vOS 26.5 updates it's also novel to get a map attached to an Immersive Space.
Maps stopped rendering in attachments if Manipulation Component is set in vOS 26.5 beta. Worked fine in 26.4. Maps render normally if set in a ViewAttachmentComponent. Then ViewAttachmentComponents  struggle to register two-handed-pinch to zoom. Seems to only register 1/30 or so instances. Two-handed-pinch-to-rotate works normally and consistently which is odd. To accommodate I reimplemented two-handed-pinch-to-zoom with RealityKit's Magnify Gesture and reimplemented double-tap-to-zoom with RealityKit as well. Rotate is handled in an Immersive Space from the Manipulation Component
Taking some vacation and won't have my avp for testing so going to focus on Client ID management ux and possibly a map picker for but then plan on drawing lines between the selected geometry and their attribute views when I get back and can do more of the fun prototyping.
Please share anything or ask any questions. The community around AVP is SPARSE. Understandably so.
ArcGIS map browsing in AVP with manipulation component and gaze-to-click
ZacharyKline
Hello.
Cool project, thank you for sharing! I was catching up on this recently and I was able to find the root cause for the two problems you pointed out. I'll DM you.
