SceneView Not Rendering Graphics or 3D Map When Using .geoTracking in World Scale AR (Swift iOS)
1404
08-18-2025 05:52 AM
nvsraju0979
I'm working on an AR project using ArcGIS Runtime SDK for iOS with a world-scale ARSCNView setup. I have a SceneView configured and everything works fine when using .worldTracking mode — the 3D map and graphics load and display as expected.
However, when I switch the tracking mode to .prefergeoTracking  or .geoTracking using:
    WorldScaleSceneView (trackingMode: .preferGeoTracking){ proxy in }
the scene goes blank — no graphics or 3D map content appears. I’ve already ensured location permissions are granted, and the GPS is working. But still, the scene remains empty when using geo-tracking.
Has anyone else faced this issue? Is there something additional I need to configure for .geoTracking to render the scene correctly?
Any help or guidance would be greatly appreciated!
Thanks in advance!
Destiny_Hochhalter
Hi @nvsraju0979,
Thanks for your question. There are a few possibilities why 3D content may appear using the `worldTracking` tracking mode and not when using `geoTracking`.
The `geoTracking` mode uses the `ARGeoTrackingConfiguration` which has a few requirements:
- The device used and geographic area must support geotracking.
- The ARCoachingOverlayView dismisses and geotracking localization completes.
- The trackingMode should be set once. Updating the trackingMode after the WorldScaleSceneView is initialized is not supported.
For the scene view and graphics to render:
- Check if there is a required API key that is not set.
- Add the scene view graphics after geoTracking localization.
  - To check this, use the `WorldScaleSceneView.onGeoTrackingStatusChanged(perform:)` closure. This code snippet shows an example of adding a graphic around the initial location once geoTracking is localized.
    @State private var isLocalized = false
    var body: some View {
        WorldScaleSceneView(trackingMode: .geoTracking) { _ in
            SceneView(scene: scene, graphicsOverlays: [graphicsOverlay])
        .onGeoTrackingStatusChanged { geoTrackingStatus in
            isLocalized = geoTrackingStatus.state == .localized
        .task(id: isLocalized) {
            guard isLocalized else { return }
            let locationManager = CLLocationManager()
            if locationManager.authorizationStatus == .notDetermined {
                locationManager.requestWhenInUseAuthorization()
            try? await locationDataSource.start()
            // Retrieve initial location.
            guard let initialLocation = await locationDataSource.locations.first(where: { @Sendable _ in true }) else { return }
            // Put a circle graphic around the initial location.
            let circle = GeometryEngine.geodeticBuffer(around: initialLocation.position, distance: 20, distanceUnit: .meters, maxDeviation: 1, curveType: .geodesic)
            graphicsOverlay.addGraphic(Graphic(geometry: circle, symbol: SimpleLineSymbol(color: .red, width: 3)))
            // Stop the location data source after the initial location is retrieved.
            await locationDataSource.stop()
nvsraju
Thank you for your suggestions, @Destiny_Hochhalter . Will give a try
