On-screen keyboard leaves map blank.
1704
02-06-2023 09:53 AM
DuanePfeiffer
If the on-screen keyboard on my iPad is used, the underlying map is corrupted and no longer shows layers.
I was able to re-produce in the Examples project by adding a textfield to the PopupElementHeader.swift file to  get the keyboard to display.
EDIT: The map is still there, but is panned/zoomed to Antartica
struct PopupElementHeader: View {
    let title: String
    let description: String
    @State var text = "Hello"  // DUANE P: ADDED State var
    var body: some View {
        VStack(alignment: .leading) {
            // DUANE P: ADDED TEXT FIELD SO KEYBOARD DISPLAYS
            TextField("Work Needed", text: $text)
                .frame(maxWidth:.infinity, alignment: .leading).padding(5).background(Color(UIColor.systemBackground)).border(.gray).cornerRadius(7)
            // Text views with empty text still take up some vertical space in
            // a view, so conditionally check for an empty title and description.
            if !title.isEmpty {
                Text(title)
                    .multilineTextAlignment(.leading)
                    .font(.title2)
                    .foregroundColor(.primary)
            if !description.isEmpty {
                Text(description)
                    .font(.subheadline)
                    .foregroundColor(.secondary)
        .padding([.bottom], 4)
DavidFeinzimer
Hi Duane, thank you for reaching out and reporting this! From what you've described above, this resembles a known issue that we're working on addressing. In the meantime, I can suggest two different workarounds.
  1. Use the `.ignoresSafeArea(.keyboard, edges: .bottom)` modifier on your map view
  2. Use the `.padding([.bottom], 0.1)` modifier on the highest level view in your heiherchy before your map view. (0.1 is a good amount because it is practically invisible).
Hopefully one of these two workarounds will work for you in the meantime. I've attached a modified version of your code with my workarounds commented out for you to experiment with.
Internal Ref: Common #13571
DavidFeinzimer
DuanePfeiffer
Work around 1 seems to have done the trick.  Thanks!
