XML Workspace not being created with X-Ray
3833
06-24-2013 11:55 AM
MapManOregon
I installed X-Ray, and was following the steps on this web page.
http://resources.arcgis.com/en/help/localgovernment/10.1/index.html#/Migrating_your_data_to_the_Loca...
However, I don't see an XML  document in the Contents tab after I create my new LocalGovernment file gdb.
FROM ESRI HELP: In the Contents window, click the LocalGovernment.xml workspace document. This will load it into the X-Ray XML Workspace Document parameter.
This is the error I receive when I click on the X-Ray button "Open Selected Workspace document."
"Invalid XML Workspace: "
Any thoughts?
Thanks.
keith
Dawn_Scott
I am having the same exact problem.  Looking forward to a reply on this.
ChrisJensen
I think the xml file they are referring to is what you downloaded with the Local Government template.  Afer extracting the .zip ,there is an xml file.
HeatherEisan1
The xml referred in the documentation is the LocalGovernment.xml. You can download the LocalGovernment.xml here
ChristopherStrother
Downloaded the LocalGovernment.xml thanks to the above post, but still get this error message even though I have Excel installed:
[ATTACH=CONFIG]34764[/ATTACH]
