Stated Area Field
2356
04-09-2014 02:26 PM
JeffWard
Honored Contributor
We have noticed something odd occurring when we create a new parcel and create remainder parcels that the new parcel overlaps, we have noticed that the Stated Area field is getting populated for some parcels but not others.  Is there something that determines when this field is populated?
Jeff Ward
Summit County, Utah
ChrisBuscaglia
Hello Jeff,
The Stated Area field is only calculated when the mis-close is small, I'd check to see if the parcel has a large mis-close.  Sometimes when you "mix" new measurements with existing parcels (in the case of a remainder) you end up with a new parcel with a larger mis-close.
Chris
