Sign Inventory Solution Schema?
3545
12-10-2020 08:25 AM
WillArellano
Hello,
I just deployed the Sign Inventory Solution to my AGOL account to begin collecting information on our street signs. As I am looking through the pre-configured feature layers, I see some fields that I have no idea what they are for or what information should go in them. Is there any schema metadata available for this solution that would give more information on each field and how it should be, or could be used? I am not a subject matter expert on street signs, so I am trying to learn about them from scratch so we can build this dataset (we don't have anyone else in the city that has time to work on this with me so I am doing this alone). I am also not really sure how to relate the signs and poles layers (I assume the poles get the unique identifiers which are then assigned to that pole's signs and related based on that unique id?) or best practices for symbolizing the poles/signs to make the map useable. Any guidance would be appreciated. Thank you!
TrevorMillen
Also having this same issue, I have 75,000 posts and 115,000 faces and would like to populate the solution to try and solve some "moving to esri" issues.
I'd love some instructions or Meta data like <ObjectID = tableID, FacilityID = post id? and attachID = SignFaceID?>
Domains are all different than ours, but I can update that.
Reporting a sign down is different then our current method and I'd love someone to explain to a non-esri data manager.
Shauna-RaeBrown
I can’t find the download for the solution.  Would someone post the url?
TrevorMillen
Hello @Shauna-RaeBrown , I believe the link you're looking for is this one. https://solutions.arcgis.com/local-government/help/sign-inventory/
If anyone has a complete user guide how to implement this I'd love to convert my legacy into this solution.
Shauna-RaeBrown
Thank you, Trevor.
I appreciate getting the link.  I'm having trouble getting the solution to work, since we're on portal and getting it set up is a nightmare.  I wish esri would make it available as a downloadable geodatabase.  Apparently, that was deprecated or the download was removed about 4 years ago.  AAARRRGGGHHH!
Here's the one that I found MOST helpful
- https://community.esri.com/t5/state-local-government-questions/sign-inventory-solution-schema/m-p/...
(https://community.esri.com/t5/state-local-government-questions/sign-inventory-solution-schema/m-p/1097375#M4951 )
