Rest dynamic map service service does not display in Tax Parcel Viewer 10.1
7640
20
03-13-2013 03:32 PM
davidwray
The following Rest service does not display as a operational layer when isVisible = false
http://arcgisweb.roanokecountyva.gov/arcgisweb/rest/services/Z2/MapServer/0
When I change isVisible = true the service will display, but I cannot toggle on and off.
Any ideas?
davidwray
Thanks Mike!  It works great now.  I found that the App did not Zoom-In to the parcel so I modified the following code.  Please see
below:
Utils.js line 115 before:
//Get the extent based on the mappoint
function GetBrowserMapExtent(mapPoint) {
    var extent = map.extent;
    var width = extent.getWidth();
    var height = extent.getHeight();
    var xmin = mapPoint.x - ((2 * width) / 2.8);
    var ymin = mapPoint.y - (height / 4);
    var xmax = xmin + width;
    var ymax = ymin + height;
    return new esri.geometry.Extent(xmin, ymin, xmax, ymax, map.spatialReference);
Utils.js line 115 after:
// Added code to Zoom to selected Parcel
    var extent;
    if (map.getLayer(tempParcelLayerId).graphics.length > 0) {
        extent = map.getLayer(tempParcelLayerId).graphics[0].geometry.getExtent().expand(6);
    else {
All the Best,
David
MikeTschudi
Esri Alum
Thanks, David--I've added your enhancement to Esri's GitHub site.
Mike
davidwray
Mike,
i have added 3 operational layers to the TPV (Residential Sales, Commercial Sales and Land Sales).  Only 2 of the operational layers show up in the legend.  can you duplicate this error with the 10.2 version from GITHUB?  I can add a 4th operational layer and 3
of the 4 layers will show up in the legend.  Also, if I only have 2 operational layers in my config.js file both layers need to be
checked in order to perform the identify function.
I have attached the config.js file that I am using for your review.  Is this a bug or am I missing something?
David
davidwray
Mike,
David
I tried attaching the config.js file, but it was too large to upload.  Below is the code snippet of the operational layers configuration from the config.js file.  is anyone else experienciong a problem with the operational layers?
    // Layer data is shown in the info window for parcel,sales and foreclosures.
    // Key is used as an layerId while adding this layer to the map and has to be unique
    // Title will set the layer name of the infowindow
    // ServiceUrl is the mapservice URL for the layer
    // isVisible is the boolean parameter to check if the layer is a currently visible or not
    // isDynamicMapService is the boolean parameter to check if the layer is a dynamic map service or not
    Layers: [{
        Key: "parcelSales",
        Title: "Qualified Residential Sales (Past 6 Months)",
        ServiceURL: "http://arcgisweb.roanokecountyva.gov/arcgisweb/rest/services/LGM/homesales/MapServer/2",
        isVisible: false,
        isDynamicMapService: false,
        Fields: [{
            DisplayText: "Parcel ID:",
            FieldName: "${PARCELID}",
            DataType: "string"
            DisplayText: "Site Address:",
            FieldName: "${SITEADDRESS}",
            DataType: "string"
            DisplayText: "Structure Type:",
            FieldName: "${RESSTRTYPE}",
            DataType: "string"
            DisplayText: "Transaction Date:",
            FieldName: "${TRANSDT}",
            DataType: "string",
            isDate: true
            DisplayText: "Grantor:",
            FieldName: "${GRANTOR}",
            DataType: "string"
            DisplayText: "Sale Amount:",
            FieldName: "${SALEAMNT}",
            DataType: "double"
        Key: "commercialSale",
        Title: "Qualified Commercial Sales (Past 6 Months)",
        ServiceURL: "http://arcgisweb.roanokecountyva.gov/arcgisweb/rest/services/LGM/homesales/MapServer/0",
        isVisible: false,
        Fields: [{
            DataType: "string"
            DataType: "string"
            DataType: "string"
            DataType: "string",
            isDate: true
            DataType: "string"
            DataType: "double"
        Key: "landSale",
        Title: "Qualified Land Sales (Past 12 Months)",
        ServiceURL: "http://arcgisweb.roanokecountyva.gov/arcgisweb/rest/services/LGM/homesales/MapServer/1",
        isVisible: false,
        Fields: [{
            DataType: "string"
            DataType: "string"
            DataType: "string"
            DataType: "string",
            isDate: true
            DataType: "string"
            DataType: "double"
        Key: "taxParcelLayer",
        ServiceURL: "http://arcgisweb.roanokecountyva.gov/ArcGISweb/rest/services/LGM/TaxParcelQuery/MapServer/0",
        OutFields: "PARCELID, SITEADDRESS, OWNERNAME",
        ParcelQuery: "UPPER(PARCELID) LIKE '%${0}%' OR UPPER(SITEADDRESS) LIKE '%${0}%' OR UPPER(OWNERNAME) LIKE '%${0}%'",
        LocateParcelQuery: "PARCELID = '${0}'",
        DisplayFields: ["OWNERNAME", "SITEADDRESS"],
        UseColor: true,
        Color: "#00ff00",
        Alpha: 0.25,
        Fields: [{
            DisplayText: "Tax Parcel ID:",
            DataType: "string",
            isLink: true,
            href: "Photo.htm?ParcelId=${PARCELID}&SiteAddress=${SITEADDRESS}"
            DisplayText: "Owner Name:",
            FieldName: "${OWNERNAME}",
            DataType: "string"
            DisplayText: "Neighborhood:",
            FieldName: "${NGHBRHDCD}",
            DataType: "string"
            DisplayText: "Deeded Acreage:",
            FieldName: "${Deeded_AC_Char}",
            DataType: "string"
            DisplayText: "Estimated Acreage:",
            FieldName: "${CALACREAGE}",
            DataType: "string"
            DisplayText: "Legal Description:",
            FieldName: "${PRPRTYDSCRP}",
            DataType: "string"
            DisplayText: "Year Built:",
            FieldName: "${YEARBUILT}",
            DataType: "string"
            FieldName: "${RESSTRTYP}",
            DataType: "string"
            DisplayText: "Total Fin Sq Ft:",
            FieldName: "${TotalFinSqFt}",
            DataType: "long"
            DisplayText: "Land Value:",
            FieldName: "${LNDVALUE}",
            DataType: "double"
            DisplayText: "Building Value:",
            FieldName: "${BuildingValue_s_}",
            DataType: "double"
            DisplayText: "Total Market Value:",
            FieldName: "${CNTASSDVAL}",
            DataType: "double"
            DisplayText: "Trash Service:",
            FieldName: "${TRASH}",
            DataType: "string"
            DisplayText: "Bulk Service:",
            FieldName: "${BULK_}",
            DataType: "string"
            DisplayText: "Elementary School:",
            FieldName: "${ELEMENTARY}",
            DataType: "string"
            DisplayText: "Middle School:",
            FieldName: "${MIDDLE}",
            DataType: "string"
            DisplayText: "High School:",
            FieldName: "${HIGH}",
            DataType: "string"
            DataType: "string"
            DisplayText: "Tax Map Link:",
            FieldName: "Click Here",
            DataType: "string",
            isLink: true,
            href: "http://imsweb.roanokecountyva.gov/GIS/Roanoke2/parcelID_taxmaps/${TAXMAPLINK}.PDF"
            DisplayText: "More Property Data:",
            DataType: "string",
            isLink: true,
            href: "http://webpro.roanokecountyva.gov/Landing.asp?ParcelID=${PARCELID}"
            DisplayText: "More Zoning Data:",
            DataType: "string",
            isLink: true,
            href: "http://webpro.roanokecountyva.gov/ZoningLanding.asp?ParcelID=${PARCELID}"
            DisplayText: "3-D Pictures:",
            DataType: "string",
            isLink: true,
            href: "https://picolsvr.roanokecountyva.gov/efs/login.php?user=public%40pol.com&pass=5f4dcc3b5aa765d61d8327...{LATITUDE}&lon=${LONGITUDE}&v=p&o=s&type=ob&level=n"
            DisplayText: "Google StreetView:",
            DataType: "string",
            isLink: true,
            href: "http://maps.google.com/?cbll=${Y_COOR},${X_COOR}&cbp=12,${SV_DEGREE},,0,5&layer=c"
            DisplayText: "Tri-View:",
            DataType: "string",
            isLink: true,
            href: "http://data.dualmaps.com/dualmaps4/map.htm?x=${X_COOR}&y=${Y_COOR}&z=16&gm=0&ve=4&gc=0&bz=1&bd=0&mw=1&sv=1&sva=0&svb=${SV_DEGREE}&svp=0&svz=0&svm=2&svf=0&sve=1"
All the Best,
David
MikeTschudi
Esri Alum
Hi David,
You've found some interesting issues, but I cannot determine the causes yet.
Missing legend items:  I've narrowed it down to an operational layer claiming to not have a symbol even though the symbol has been clearly transmitted over the network as part of the layer.  In the version of the software that you're using, that missing symbol prevents the layer from appearing in the legend and the symbols from appearing on the map.  Especially odd is that, if I configure the app to have multiple copies of a service, it's possible for one copy to have a symbol and the other to be missing one.
Identify problem:  I can reproduce it easily using your services.
I also see that the latest version of the software does not gracefully handle layer names long enough to wrap onto a second line.
I don't have solutions for you yet, but I wanted to let you know that I've been working on it.  Your configuration has been extremely useful--thank you for supplying it.
Regards,
Mike
davidwray
Mike,
Thanks for the update.  Also, I am unable to perform the identify function when I have only the first layer in the legend checked.  If I check the 2nd or 3rd layer in the legend the identify functionality is enabled.  Are you able to reproduce this issue?  If so, do you think it is related to the symbology passing thru the service?  Please let me know if I can be of any assistance.
All the Best,
David
MikeTschudi
Esri Alum
Hi David,
My very-short "Identify problem" stood for a bunch of problems with identify, including the one that you mentioned. 😞
You've been very helpful by pointing out the problem and providing the services--the challenges so far have been to figure out what's happening; the next challenges are to figure out how to solve them!
Mike
davidwray
Hi Mike,
I thought I would check on the status of the identify issue.  Any updates?
All the Best,
David
MikeTschudi
Esri Alum
Hi David,
Progress has been stalled due to both technical challenges and time assignments, but I very much want to solve this one.
Regards,
Mike
JayGeisen
David,
I sent you a PM, but not sure you will see it so I'll post here too.
How were you able to add a dynamic service to the application? I've tried everything I can think of, but I can't get anything to display. Would you mind posting your config file, please? Ideally, I'd like to be able to add a dynamic service that doesn't appear in the basemaps list.
Jay
