Populate field with shapefile name using Attribute Assistant
772
12-19-2017 01:51 PM
KearaBurke
What variable is the current shapefile name (TABLENAME) stored in while using Attribute Assistant? There is a method (MapInfo) that can ouput the shapefile folder name, but I need something that outputs the shapefile name. attributeassistant getfield attribute table fields
