Map Book
2152
02-16-2018 10:38 AM
JoeFrydrych
I need to create multiple maps based off of individual polygons.  I know you can create a map book or strip maps to create this, but Is there a way to generate individual maps based on all the individual polygons.  Just trying to save some time instead of creating individual MXDs for each individual polygon.  Any help is appreciated.
Thanks!
DanRios
I have this same situation: I have a project area with parcel polygons that contain Tree locations.  I need to create a map book that shows individual polys and associated tree_point locations.
ChrisDonohue__GISP
MVP Alum
If one wants to create a map based on individual polygons in a layer, those polygons can be used as the Index layer instead of the more typical Strip Index Map or Grid Index Map.  See the example below:
The index layer does not have to be a grid. It can be map features. For example, you can create Data Driven Pages using a polygon layer of U.S. states. In this case, a page is created for each state.
Source:  Creating Data Driven Pages—Help | ArcGIS for Desktop
Chris Donohue, GISP
JoeFrydrych
Chris,
I was messing around before you sent this and figured that out.  Is there anyway to just show one specific individual polygon per map?
ChrisDonohue__GISP
MVP Alum
If the issue is that you would like to suppress other polygons in a layer except the single one of interest for that map (due to proximity, overlaps, potential confusion, etc), I believe it can be done with scripting, but I don't recall at the moment the particulars.
Chris Donohue, GISP
