Is Attribute Assistant compatible with 10.4.1?
5146
11
07-01-2016 03:59 AM
DuncanHornby
MVP Notable Contributor
Whilst trawling the GIS SE site I became aware of something called Attribute Assistant, an add-in that had some clever attribute assisting functionality. I have downloaded it and installed it, believed I had created a sensible rule then ran it. It bombs out Arcmap with object not set. So thinking I had not done something correctly I reviewed what I did, still thought it was OK but then tried to turn off/on the add-in using the button on the tool bar. Button goes red and shows this error:
This immediately makes me think that this add-in is not compatible with 10.4.1 and would explain why I could not run the generate ID rule. I am using Windows 8.1. Can someone from ESRI confirm this? Are there any intentions of making this 10.4.1 compatible?
MichaelHamrick2
The table does not have the exclamation point, just the button to turn on and off the attribute assistant.
Larry Masters
Engineering/GIS Coordinator
122 Hwy 25-E
Newport TN 37821
Office: 423-623-3069 ext. 123
865-475-2300 ext. 123
Cell: 865-322-2308
“This message may contain confidential and/or propriety information and is intended for the person/entity to whom it was originally addressed. Any use by others is strictly prohibited.”
JoeBorgione
Commish5‌ -  perhaps you could elaborate on the problem you are having.  You say there is an exclamation point in the AA tool bar?  How about a screen shot of what's going on?
