Intersect tool; automatically changes the field names.
10559
21
09-23-2015 08:55 AM
ToyaShannon
Why does the attribute name fields change after performing an intersect?
ToyaShannon
Thanks all. I basically uninstall/reinstall ESRI and somehow it worked. My IT team indicated that there was something going on with the malware. Thanks!
LukeWebb
Are you sure that when you tried to run the tool, your data was not joined to a dataset?
This causes the output field names to come out as: dataset_Fields
Which then gets truncated to dataset_
So one of your datasets in the join was called geocoding?
