Help with parcel Viewer?
3208
12-03-2012 09:10 AM
Banff_GIS_Department
hi there,
I'm trying to get the Tax Parcel Viewer up and running using my own data.
I was able to set and configure the viewer using the documentation and the LGDM datasets.
The service is starting fine, I can search for and 'find' parcels using addresses and a list of possible address matches is listed along the left hand side, but whenever I try to select a parcel from the returned search all I get is "Parcel not found at specified location.".
**I can search for "110" for example and get about 10 matches back and get the error above.
however, if I fill in more of the search window, like "110 Bear" It flashes a result but then lists nothing in the sidebar and simply returns the "Parcel not found at specified location.".
What is this telling me?  I have all my parcel polys loaded (just polys).  But I can't get them to show up on the map.
I'm using the 10 version.
Any other details I can provide to help trouble shoot?
here's the service http://banffmaps.ca/DEV_ELOP_TOB/taxparcelviewer/
thanks for any help
Steve
(seems like I do this a lot - post a question, then 10 mins later figure it out....;))
Anyhow, in case anyone else has this issue - I hadn't populated my PARCELID fields at all yet - as soon as I did a field calc to match what we call ROLL numbers, it seems to be working now.
Cheers
Steve
