Josh when you hear the beep do you see a message like this one...or is there just a beep?
If the message is just not showing up, then I haven't seen the issue before, my suggestion is to report it to Esri Customer Service so they can trouble shoot and potentially offer a solution or address it in an update.
Ok, I discovered that my Normal template was corrupt so it was not a bug that could be recreated, it was something on my machine, problem solved. Thanks for your help Jeff, Brian and Steven.
Nope just the beep. when I first open an ArcMap session Single Line Input shows up but goes away and hovering over it brings it back. I guess I will report it to Esri support. This is such a bizarre error I don't know what else to do.
Thank you for investigating this. I just ran into the same exact issue with one of my users. Thank you!
I'm having a similar, but not exact, problem. My Geocoding Toolbar will not accept any inputs. I'm using my own locator on 10.3. When I type in an address for it to locate and press Enter, nothing happens. No sound, no error message, nothing. It even occurs when using the World Geocode Service.
Hovering over the single line input shows the normal, "Find Address" dialog box. But right-clicking the box shows this:
I've run MXD Doctor and found no corrupt items. Any ideas? Suggestions?
Did you try deleting your normal.mxt? It can be found in C:\Users\<user>\AppData\Roaming\ESRI\Desktop<version>\ArcMap
Thanks for the response. I haven't tried that yet. I'll try that and get back to you.
